Ghetto acrylic/polycarbonate case.
munkle
So here is my ghetto acrylic/polycarbonate case that I made from some scrap that I bought. Maybe cost me $10-15 in acrylic/polycarbonite and $5 in bolts.
One of the supports broke when I was drilling the holes so I just glued it back together. And I suck horribly with a dremel. Oh the cpu fan isn't that dirty, looks alot worse than it really is.
Well its 100% better than anything I could do! Looks good so far. My only issue with clear cases is figuring out where you would hide the wires? I think a modular power supply would suit this case well. Good luck!
Dude! Where'd you get plexi so freaking cheap?!
I stopped by Home Depot and to get that kind of surface area in Lexan would cost me something like $150. And that's only 2.5mm thick stuff too.
Go to a place that sells only acrylic and polycarbonate they will likely sell scrap pieces, where I get this stuff they sell it at $1.10 a pound. That's why the top is made up of 4 smaller pieces. The supports were already cut to that width, they were just big long strips and I cut them to length I wanted.
