GFX issues
Ckamc
I currently have a plain leadtek 6600 agp card and been having several issues with Suse 9.3 and other linux distro's. during configuration of my graphics during install I am unable to get any distro *havent tried mandriva yet* to display properly.
The issue: when I go to test out my configurations The screen colors do not display properly and the resolution is corrupted to a 320x240 resolution!
Thus I cant do any boot-up's into any linux distro so far with out this issue *will take pics soon* and was wondering about the current support among various distro's and any ideas on what I should do would be greatly apreciated!
right for starters, all distro's are LINUX!!!!!
All they are is packaged programs with a few custom management programs
IF something works in one it will work in the other!!!
Now back on topic, you say
Well leadtek arnt a GPU producer so I guess you mean nVidia 6600 (good card),
you will need to install the drivers, SuSe might come with it otherwise d/l and install.
Bascially DO NOT TEST YOUR DISPLAY if that is what causes it to go funky.
So get SuSe packaged nVidia driver then try test display (when correct card selected)
Ok so how do I get more drivers when I dont have wireless configured to grab new updates for suse before hand? I may just try to get it to work with my old tnt2 card for now while ic what kind of updates I can get from suse and become able to setup my wireless
I was just wondering if there have been any updates that other distro's have that Suse 9.3 doesnt have unless I get the online updates.
