Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
Just be VERY careful not to get any on anything but the processor core itself. AS is conductive and does wierd things if you get it on the pcb and is damn near impossible to get off. (I know )
I have used AS on my GF4 Ti card. I have had no problems.
I have a suggestion for you...
When you apply the paste put some masking tape around the core. That way you don't have to worry about it contacting the pcb or getting under the core.
