gf 6 6600 cooling help
Rhodesy_71
is there any software out there what can mesure the temp of the core gpu and memory on the graphics card as ive got it clocked but need to know how hot it is before insalling a better heatsink and fan
Have you checked the nvidia settings (little green nvidia logo sitting in your sys tray) It should tell you everything you need to know.
i dont think any models have sensors for the memory though. that would be sweet
A bios edit and flash can enable the temp monitor :D (did it on my PNY 6600GT AGP)
were would i get new flash bios from ect and how can u tell what bios version is already installed
my card is a pny gf 6 6600 256 mb ddr ram
core clock o/c 390 from 300
memory speed o/c590 from 500
the cards running stable but i need to know temp so i can then cool it more if so and try get some more power out of the beast
