Getting the light on in Sonata
How do you hook up the blue light in the USB door? I sorted through all the mess and got my firewire, USB, audio, and different LEDs up but somehow missed the blue light.
there will be a molex connector dangling in there somewhere too........it has 2 thin (1red/1black) wires going from the connector to the front panel......those are for the lights.......just plug it in
That is what I was going to say, there should be a molex connector with 2 wires coming out of it. Follow you cables, or take off the front Bezel.
its a white molex connector behind the hd trays. the leds get really anoying tho :eek:
if you dont like the LEDs then just put a switch in (like cut the ground, and run the ends to a switch or button somplace)
