Getting stuck at DMI Pool Data
hatzitaskos
n00bie
The saga continues...sorry to bother you again guys.
So, I'm building my new Abit AV8, Athlon 64 3500+ 939 pin system. I had some problems with the M/B beeping, but when I connected a CPU fan and made it run fast enough, the beeping ended.
Now, unfortunately, I have another problem. I managed to boot normally, but Windows XP setup did not recognize the SATA hard disk. So I tried to reboot, so as to check out the driver floppy that came with the M/B.
The problem is, ever since I rebooted, booting gets stuck at the "Verifying DMI Pool Data" message. Any idea what might be causing this and what I can do to stop it? Would refreshing the CMOS do anything?
Thanks,
Kostis
