Getting SLI, need info on PSU
Typhon
Im planning on getting the MSI SLI board with hopefully 2 6800 Ultras PCIE
What kind of PSU will i need
currently i have a Power and cooling PSU but it doesnt have pcie cables.
Another thing, dont i need a psu with 2 PCIE cables?
Thanks!!
As long as you have a decently sized PC Power and Cooling I think your current power supply could handle the load of an SLI system. You would need two PCI Express power connections unless they make some sort of adapters to use some existing connections, which I think they might. I don't think the connectors are really that complicated so you could probably buy the connectors themselves and splice them into your existing power supply just fine. PC Power and Cooling could probably add them to your existing power supply for a fee as well.
PCP&P should revise their express PSU to have 2 PCIE cables instead of having only 1 and 6 sata connectors.
most of the pcie cards w/ a needed power connection come with an adaptor for the new connection (the adaptors use 2 molex connections). so if you think your current psu would be ok you can just use 2 adaptors for the actual cards.
