getting Asus P4c800-E deluxe, help
Zeke
I have a question, I'm just switching my Intel D875PBZ for the Asus, am I going to have to reformat and reinstall windows? Or should I just be able to uninstall of the intel software and it will be ok?
Also, are there going to be any problems with the Asus if I'm using a Koolance EXOS watercooled set up? (i'm not putting any waterblocks on the motherboard, I'm leaving it's default cooling)
comon guys, this must be a pretty simple questoin for any of you [H]ardcore enthusiasts, help a guy out... :(
Could go either way. I have experienced it both ways. I use a corporate code for Windows installations and I don't have to many problems as long as the boards have similar chipsets and the same vendor ID. However drastic changes like brands of motherboards with different chipsets will cause me to have to reinstall.
However I did do a install for a friend who had a Intel D865PERLL and It was switched out for an Asus P4C800 Deluxe. I didn't have to reinstall at all for that job.
With regular codes I have heard that you have to redo activation alot more frequently. Meaning that it is much more likely that you will have to reinstall. Tough to say though. Sometimes Windows XP seems more forgiving than others.
To make matters easier you could always sysprep your machine with the pnp switch and reseal modes turned on. Also choose mini-setup. If you do it this way you increase your odds of not doing a full reinstallation.
The sysprep utility can be found on Microsofts website. You'll be prompted to go through some questions and a have to re-input the product key but when your done with that you'll find all your programs and software are still there are are any desktop settings and preferences.
I do stuff like this all the time at work. I have to clone different units with the same image. So i've seen it go either way.
all I'm doing is swtiching mobo within the same chipset, they are very similar boards so I'm thinking I won't have to, but thanks for your experience, it's always nice to get advice from people who actually know :)
I just made a switch from my dell dimension 8300 with 875P mobo to Asus P4C800-E Deluxe using dell winxp home edition.....You need to reinstall windows or either configure the Asus internet connection for you to register windows......I had to reinstall the damn thing coz my Asus lan connection was properly configured.....but i had my cd key so i used'em and it worked......Your remedy is to install windows xp then if you have your cd key with you just fill'em up then connect....your done.............
welcome to asus world.......
