Blinkme323
- Feb 8, 2005
Hi guys, shortly I will be receiving a DTR 3000 and DFI LP UT. The DTR is stable to 2.8ghz. The DFI can do >335 HTT and has some glitches with the 133 divider.
I have been out of the s754 scene for a long time. IS there anything I should know about this motherboard? What is the best bios, any quirks, etc?
I am in the process of choosing my ram, but need to know some facts about the DFI first. What is its max DRAM volts. I saw 3.1, but read that you can get to 4.0v with a jumper or bios. I don't have an adjustable PSU.
Also, if somebody can recommend ram that works well with DFI's that'd be great. Hopefully, I'll run 1:1 at 300, but I will probably need to use a 166 divider in my price range. I have about $100 to spend, cheaper is better.
Thanks for the help!
