Get rid of those OC utils
Im using ATI tool 0.0.22 works great for me. I'll wait for some reviews before making a switch.
Its a bios editor so that you don't need to use things like ATi tool. You simply edit your bios and input what clock speeds you want and save. Then flash your card with the new bios. Then your clock speeds are set at what ever your card can handle.
too bad that you'd still need to use ATi Tool to control the card's fan speeds on a soft modded XT PE.
I guess I didn't think of that since mine is watercooled. Although I flashed my wife's PC (it doesn't go past 510) and temps don't go high enough to need ATi tool to kick the fans on...
