Get get stable...
I have a 2.6c on a P4C800E Pushing 3.2, but I can't get it prime stable.. at stock voltages it will give me an error, and when I raise the voltage to 1.648 (1.6 but overvolted a little) Prime 95 will go longer before error then the computer will completlely FREEZE. I am running Ocz gold 1g ram at stock timings. I have the dramm voltage to 3.8, high as it will go, and everything else is stock. Any recommendations. It will run fine, just crashes Prime 95, can I use the computer like this day to day use... not good idea?
Prolly not a good idea to use it day-to-day... A lot of people use it even if it's not prime stable, but problems can start to show up... (Data corruption, random lockups, etc...)
I dunno, maybe you'd be okay with it, but personally I wouldn't risk it for a few extra mhZ. :p
