I couldn't find a thread about sound cards so here this goes.
I've been thinking about getting a new sound card...But the problem is my SLI setup covers up my PCIe slot so I would either have to move my GPUs or just go with a normal PCI sound card, which would also then have to fit under the SLI bridge. Searching around I've seen the Creative cards to be the most used cards, and the Asus and HT Omega cards to have good reviews as well, with the Omega cards having the upper hand on newegg. So with probably only being able to use a regular PCI slot, what are my choices?
Theres onboard... which right now is ok, but I don't know if I'm missing something.
So any recommendations? tales of success/frustration? Would I even notice a big difference?
For reference I would be using it for both music and gaming probably equally, with music edging out gaming just a bit
