Hiho:
I am currently running a 4-disk R-5 array in my Domain controller. I have filled 420 of the 440 GB of space and am thinking that I will soon need more room. Considering my abysmal HD-tach performance (average read is 61 MB/s) and the fact that I don't particularly like my Promise SX4-M controller (it's PCI-X yet my dell only has PCIe slots) I am thinking that there are a lot of good reasons for getting a WD5000YS:
However, the 500 GB drives are pretty expensive. Considering that I can get the 750 GB Seagate from a forum member for 50 cents/ GB that would be cheaper than the WD option. I looked at Anand's benches and the temperature (http://www.anandtech.com/storage/showdoc.aspx?i=2760&p=11) it appears to be a "cooler" investment to get the WD drive.
What do you guys think? Should I sink $375 into the Seagate or $260 + s/h into the WD solution? In the future I will likely move back to R-5 on a PCIe card though.
- One (or two in the near term) drive(s) consumes less power than 4
- Zero raid controllers consume less power than 1
- a single disk/ raid-1 volume is less complex than raid-5, less likely to fail
- less heat in the case (I think 2 of my drives have died from heat already
