I would like to build a quiet 10*hdds nas config, using:
-RSV-L4000 case
-2*supermicro CSE-M35T filled with 10*5K4000
For the hdd cooling, i'd like to remove the noisy 92mm San Ace from the M35Ts and use instead the case fanwall of 3*120mm filled with GT for their good static pressure and low noise.
I thought using AP-12 (800RPM) or AP-13 (1150RPM), but i don't know if that's enough to keep 10*5K4000 at a safe temperature (6.4W per drive in load, so 64W max).
Do you think i can get sufficient cooling with only three 800RPM fans ?
Or do i need AP-13, or AP-14, or even AP-15 ?
-RSV-L4000 case
