Originally posted by pduan87
You might want to look into Folding@Home. Genome@home is basically a dead project, Stanford is currently supporting Folding only.
FOLD ON!!!
over here.I wish I could confirm that all is equally scored on a Celeron 500, but it doesn't appear to be so here. I also have exactly that same hardware, with 128K DRAM. The only thing possibly different is that I'm running Linux. I've recorded the score rate in points/hour as reported by qd for roughly the last fifty units I've done. Here, in general terms, is what I've seen.
Gromacs projects 53x produce about 0.280 points/hour.
Gromacs projects 51x produce about 0.215 points/hour.
Gromacs projects 39x produce about 0.220 points/hour, but are variable.
Tinker projects 62x produce about 0.180 points/hour.
Tinker projects 20x produce about 0.120 points/hour.
SPG project 799 probably produces about 0.260 points/hour now. My latest data is from before when the formula was doubled on 6 February 2003.
So even on a machine without the accelerated instruction sets, Gromacs scores considerably better than Tinker. Some of the other variations might be due to cache performance differences with the different internal Gromacs methods.
Some of these project series, mainly the Gromacs ones, may be primarily beta projects, so it's possible that when corresponding work is released as new projects for the general community, not only will it run with fewer errors, but the scores will line up a little better too.
_________________
-Dick Howell (rph_iv)
