generic "will these parts work for my first WC setup?" thread
Hellpud
So I'm finally able to put together my first WC setup and I just wanted to get some opinions on whether the parts im looking at will work out or not. Im pretty much planning on mounting the rad externally with everything else inside. any suggestions on the order in which i should run the loop would be much appreciated as well. Thanks fellas!
TDX cpu waterblock or D-tek fusion
MAZE4 for the chipset
Danger Den 8800gtx waterblock (not sure if ill get this immediatly but if not ill get it soon, damn thing puts off waaay too much heat)
Danger Den Black Ice GT stealth 240 rad(kinda thinkin i might need a 120x3 instead)
Swiftec MCRES - micro res
D5 pump
misc fans, tubes, clamps and fittings
My Specs:
E6600 (currently at 3.2)
eVGA 680i mobo
Corsair dominator XMS ddr 800 ram
WD 150 gig raptor
OCZ 700w gamextreme psu
eVGA 8800gtx
gigabyte 3d aurora 570 case
it all looks good, but id definitely go for the fuzion and swap the rad for a mcr220 or mcr320 if you can :)
Oh, i thought you meant you were going to use generic parts, like garden hose, sink valves, and tupperware reservoirs. My bad.
go for the fuzion, and a bigger rad. (maybe a 120mm x 9, for overkill effect)
you would be amazed with what i can accomplish with little more than a snorkel, surgical tubing and an avocado but i figured i would splurge and get a fancier set up. ;)
i got my S-TDX up for sale :p
other wise your setup looks decent (but id get the larger rad if you jump in with the video card.
sweet, i think ill have to start ordering everything soon if i have a few thumbs up. As far as the rad goes i should be ok with the mcr320 that NHO recommended right?
also any suggestions on what an ideal loop would be for all this stuff? thanks again for the tips fellas.
so its begun... just placed orders for my D5 pump, MAZE4 block and MCRES res. Still have to call my bank tomorrow to add my work address to my "safe shipping" list or whatever to order the rest from jab-tech.com. Cant wait! :eek:
I'd switch to a Swiftech rad instead and would opt for a 320 since you'll have a CPU/GPU/Chipset loop. A Swiftech MCR220 should suffice, but I'd always rather have overkill than not enough. Go with the Swiftech MCR320.
For your Full Cover block, I'd avoid DD's FC's. I had a pair and their craftsmanship on those things were horrid. DD even put a batch out there that had microfracture leaks. If you want FC's, the best out there are the EK ones. Buy those instead, not only do they look better, but they perform better than the DD's.
For the CPU block, get the Fuzion. It's pretty much a two horse race in the CPU department and the Fuzion beats the Swiftech GTX in most cases and is aluminum free to boot.
