Generic therrmal compund $0.99 FS @ mwave
Found it, ordered a pair. I ask fresh out of as5 so this is great.
Posted via Mobile Device
They had a 14g tube of AS aluminia for $5 free ship the other day. You'll get alot more that way and it's not questionable quality.
Edit2: Wrong link 14g is $10 now.
Thermal paste is probably the cheapest part of a build, so I'm not sure why you'd want to save a few dollars (literally) on some no name thermal paste. Like, you spend hundreds of dollars to lower your load temp by a few degrees only to have it offset by buying the crappy $1 TIM. That said, I don't mean to crap on the thread or anything, and having a spare anything is always useful, especially for only $1.
The myth of superiority surrounding various TIMs is a source of continuing amusement to me. Thanks for that.
Not to threadcrap but if you're going to spend the money and get something I suggest this. Then you can go crazy with it whenever you want to test out a certain heatsink you have sitting around, or anything else. Plus, it's nonconductive and noncapacitative, you can go hog-wild. :p
http://cgi.ebay.com/Arctic-Silver-C...754?pt=LH_DefaultDomain_0&hash=item4aaa954f2a
Or if you want high performance spend $4 on this Shin-Etsu G751, it pwns for the price.
http://cgi.ebay.com/Masscool-G751-T...890?pt=LH_DefaultDomain_0&hash=item23105cf52a
+1, it's so true. I finally learned this and now I pride myself with having spare parts and accessories to accommodate different situations and needs. TIM is too cheap to skimp on, and is one of the easiest things to improve in terms of price/temperature.
I wouldn't get that that 22g tube off ebay. I bought some of that stuff and it was considerably thicker than the same stuff I got from newegg and had worse temps. I think it was a cheap Chinese counterfeit. Maybe that seller is legit but I would say buy it from a real website not ebay.
I like this stuff, and it has free shipping.
http://www.amazon.com/DIAMOND-CARAT-...4318705&sr=1-1
I have used Diamond and its definitely good stuff, but for 99 cents shipped I am going to have to try the generic stuff (not on anything good I mean) and see how it handles O/Cing on my cheaper AMD setups. But for my newer and more expensive i7 I am going to have to use the rest of my Diamond tube. No way will I put 99 cent goo on my pricey chip when I get it :D
mwave now has Arctic Silver Ceramique High-Density Thermal Compound 2.5g for 4 bucks shipped.
Dead link
I had someone post the same response in one of my other threads with an mwave link. I clicked the link in IE8, it works. Right clicked, copy shortcut, open Firefox, paste in address bar - works. Not sure what's different on your system, but the link is good.
Search for "BA31168" if you can't make the link work.
I'm not implying that it's great stuff. But it'll be a LOT better than the dried-out caked-on stuff in that P4 machine at the office with the dirty fans. When you pull it apart to clean out the fan, scrape off the old nasty stuff, and freshen it up with your $0.99 tube.
Even the el-cheapo sub-buck stuff works great on laptops. About half of the old laptops I get it to work on are overheating because the thermal material was bone dry and cracking, serving absolutely no use. Fresh buttering of goop, good to go. I personally stay away from any silver-based stuff, esp. on small laptop CPUs where there are still open spots on the CPU around the core like the old Socket A CPUs.
I tried some good expensive silver on my last comparison build where I put together two machines with nearly identical parts (Q6600s on similar mobos) and the difference in temps was well within the margin for error. I'm not saying all thermal paste is good, of course there's tons of bad out there -- stuff that has sat too long, mixed improperly, or with the wrong ingredients... but properly made "cheapo" thermal paste offers at least 90% the performance of any supposedly "high quality" TIM I've ever used... cheapo is exactly what I've used on every gaming rig I've built for myself (of course all overclocked) for what... 14ish years now? I'm pretty certain cheapo TIM gets the job done.
"YMMV"
I'd rather not take any chances with something I'm going to be juicing as hard as I can...
To each their own.
