Generic Case Modding
hity645
I was given a free mid-tower case that I decided to use for my server. I didn't quite like the look of it so I decided to mod it. I added 2 front usb ports, and cut out the "naked lady" from the trucking mud flaps on the side, painting the inside red where ima throw some cathlode lights in there and the outside will be a silver color. I did some reading and saw that we have to use a Vinyl Dye on the front bezel. Is there some other type of paint we can use? Ive checked all the local spots for paint and all they have is Vinyl and interior paint. Will that work ok? Ill post pics of before and after when im done. Thanks.
almost any spray paint will do...i got some auto paint and i htink its the best out there
the biggest part of painting is the sanding and preppin....spend alot of time on that
if i can find this link ill post this awesome howto
Yeah we got the main chassis all painted were just kinda waiting on the front bezel, i mean...im going to be using this case for quite some time so we dont want it to fall off..i might even sell it if theres a good enough offer for it. But thanks for the advise, i figured it would work good too. Read the FAQ posted here on case modding, quite a few tips there and got some info on the Vinyl Dye.
