Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
as long as you don't have artifacts or anything like that.. it should be fine.. make sure when you stress the card you turn off the AC in your room... make the room as hot as possible when over clocking... at least that's what i do.
