Boil
- Sep 19, 2015
First off; love, Love, LOVE all of the 'boutique' SFF chassis' in this forum!
Dan A4-SFX, KI Cerberus, Project mATX, NCASE M1, etc. …
But I have 'special needs'; meaning, why can there not be computer equipment configured the way I envision?!?
Rant - Why, oh WHY! did EKWB decide to forgo the PCH portion of their mono block for the Asus ROG Maximus VIII Impact mITX motherboard? The mono block designed for the previous two version of the Maximus /X/ Impact had the PCH covered & I liked that!
Rant - Why does EKWB make a specific water block for the AIC version of the Intel 750-series SSD, but NOT make one for the 2.5" version of the same? I want a total compute water cooling solution, but in the mini ITX format!
Rambling - I love the Osmi chassis, but I lament its sudden price hike. It would make an almost perfect chassis for a Hackintosh build. Yes, I am a diehard Apple user from before the Macintosh itself was an actual product. Let us NOT get side-tracked into OS X vs. Windows vs. Linux vs. Whatever here… BUT…! I do not like the 'wasted' space that is set aside for the ODD & 2.5" SSD. I would go for either a M.2-based NVMe Samsung 950 Pro or the Intel 2.5" NVMe SSD mounted in the 3.5" drive position (depending on motherboard used) for the system drive in this chassis. So, wasted space…
I also really like the Dune Case chassis, even though I feel it is a little 'fat' compared to the actual Mac Pro chassis, but I do understand that needed to be done to shoehorn the mITX board in there. The custom I/O panel is a HUGE selling point for me; no garish colors on the various I/O ports, no sideways or upside-down labels on said ports. Very little excess ports one might never use.
But what I would REALLY like to see is the smallest form factor I could get for a fully water-cooled compute system (CPU/VRM/PCH/RAM/SSD/GPU) in as small of a package as possible! I would not be overclocking, so extreme performance water-cooling would not be needed, but sufficient water-cooling to keep temps as low as possible would be wanted, if that makes any sense. I also feel that separate sub-systems would allow each sub-system to better control itself for optimal cooling of said sub-system. I would have (in the case of a hypothetical mITX-based system) CPU/VRM/PCH as one sub-system, GPU as a second sub-system, with the RAM & SSD being the final sub-system. Without overclocking or using VERY power hungry components, I could see three 140mm Hardware Labs radiators (they make some pretty hefty claims towards the amount of 'heat wattage' each of their radiators can handle, so each of my sub-systems should be no issue at all) with EKWB Predator-style reservoir/pump 'end-cap' units attached for the actual cooling component of each sub-system.
THOUGHTS…?!?
Stepping down off of my soapbox and adjusting my tinfoil bowler hat now… ;^p
THOUGHTS…?!?
