PrometheuSBoxeR
- Sep 21, 2005
I have a vast amount of questions that I am thirsty for awnsers for. They will probably lead from one thing to another, but thats what I want. Here are some questions I have just basicly about anything computers, overclocking, hardware, software you name it. I always would like to hope that mabey at least one more person has the same question so it won't only help just me. Don't feel afraid to post what you think and pictures are ALWAYS very helpful - I insist.
1. Without any active cooling on my Memory (See sig) whats the highest vdimm I should go to?
2. If im looking to get into some active cooling what are the most common and effective ways?
3. The AMD Athlon 64 X2 Dual Core Processor Driver for Windows XP found here, http://www.amd.com/us-en/Processors/TechnicalResources/0,,30_182_871_13118,00.html what do they exactly do, and are they beneficial to have?
4. The DELL 2405FPW is my first LCD, I am definitly a gamer and I like my games to run as crisp and smooth as possible. Im sure I do not speak for myself. I basicly want to make sure im getting 100% use out of my 2405FPW and have everything right to reach my goals of crisp/smooth gaming. One of many things are these drivers I found at http://support.dell.com/support/dow...&typecnt=1&vercnt=1&formatcnt=1&fileid=118667 What exactly do they do, and are they something I want to have?
5. In addition to question #4, is there anything else I want to have to reach my goal?
6. Coolbits for nVidias basicly allows you to adjust core speed and memory speed. When you adjust a frequency you must test changes. I see people reach incredibly high speeds with thier 7800GTX. I have the cooling for one, but coolbits seems to be limiting what I can do. I idle at 37C // Load is 48C. At stock speeds. I would like to get everything I can out of my video card, but I seem to be at a wall. How should I approach this?
7. Does anyone have any Lian Li PC-V1000 inside?, I would like to see some cable management pictures in this case, along with cable management I would like to see any creative mods that they think makes the case better. I am intertested to see how everyone tackled common issues with this case. Being a inverted motherboard and such.
Im going to add questions as I come up with them, to keep consolidated threads. Thanks in advance.
