general questions
redd38
Alot has changed since I bought my last motherboard and I need help getting it all straight.
Has PCI become PCI-X or are those two different things? If a motherboard says it has 3 PCI slots and a card I want says it's PCI-X are those going to work together properly? Does it need to specifically say PCI-X? And PCI-E has replaced AGP right?
SLI requires 2 video cards right? And if I'm not a gamer do I even care about SLI?
also anyone want to recommend a quality AMD motherboard?
pcie video cards need a pcie slot on the motherboard.sli is a 2 video card setup and if you dont game then sli is a huge waste.pcie has replaced agp video cards.if your not running sli then you would need an nf4 ultra board.it has 1 pcie video slot and 3 regular pci slots.the best board ive run across for a great all around board is the asus a8n-e.it does everything well.great layout,mature bios,stable as a rock.just cant say enough good about this board.been running for 10 months o/clocked and not one crash or blue screen.
you can use an sli board with 1 video card and it just dosent run sli.
the asus board loves corsair xms ram and you need a good p/supply with any nf4 board.good luck with your decision.........................................
and what about pci-x? I don't see any motherboards that have pci-x slots, just pci slots... is it the same thing?
And why does it seem like only the high-end boards have firewire? Is firewire fading out?
Hi redd38,
PCI-X is mainly used on server motherboards and is quite different to PCI-Express, a technology that you find on most consumer motherboards.
I can't explain it in detail so your best bet is to follow this link
Wikipedia PCI-X Info
Firewire is still widely used. You're right in saying that it's mostly found on higher-end motherboards. I'm sure that it's not as common (on motherboards) because there are far less devices that require it and most external devices use USB over firewire. The motherboard manufacturers are fairly limited for space when they design the boards and they assume that the majority of customers will prefer lots of USB ports over 1 or 2 firewire.
Hope this helps.
Cheers.
