never... I just make sure to ground myself first before working on them.
I don't use one. I just try to touch something metal first and find the safest surface to work on. Usually ends up being a wooden or plastic surface.
I dont know anyone who uses that stupid thing, and we have never had a problem...
To elaborate more on this, the metal you touch must be grounded, or touching it is useless.![]()
this.I ground myself and then work on the computer, haven't had a problem yet.
Why do you think that? ...
I, not thinking, ran out across a carpeted foyer and down a carpeted hallway, in my socks, during the winter, holding my beloved IQYHA back in 2003. I got to the door and said "crap, I'm still holding this?" put her in, and she worked just fine. I've never shocked anything to death and I've touched more computers than I have chicken wings. No, never wear one.
You touch the ground plane of the motherboard (shorted to the power supply case through the power cables).If the un-grounded metal you touch is at the same potential as you, and the component you touch has no charge, wouldn't you discharge into the component?
Do you think a technician aboard a flying plane cannot safely work on a semiconductor component that is inside an anti static bag because he cannot ground himself since he is thousands of feet above it (Ground)?Most of the time, the parts you're about to touch are not charged, especially if they're coming out of a brand new anti static bag.
wouldn't the safest practice be to ground the metal you want to touch, then touch it before touching your component?
The idea is to bring yourself to the same potential as all the components on the motherboard (ground plane) so that you can work on it without damaging any of the components on the motherboard whether it is grounded or not.
How about an engineer on the space station? How is he supposed to ground himself considering he is orbiting it?
An anti static bag has a very high resistance. But, it is not a perfect insulator. In other words, it's resistance is not infinite.
When you hold the bag in your hands for a few seconds, it is enough for the charge to transfer between you and the contents of the bag. So, you will be at the same potential.
Since the resistance of the bag is extremely high, the current in this case is very low and non-destructive.
