general oc question on voltages
junglism
Is it ok to leave the other voltage settings on auto while i am adjusting the vcore down, and then adjust them once i've gotten the vcore as low as it will go? Or should i enter values for them as well, close to or at their lower limits?
this is my first time ocing anything in case you couldn't tell...
thx,
nate
You should be fine leaving the other voltages on auto for smaller overclocks, so long as you adjust them later on.
