General help with my system (GFX)
donkey33
I posted here because the most help I want is with my 5900 XT.
System specs are listed below. I just got it so everything's at default but I want to see what options I have to optimise it. Mainly the 5900 XT.
I'm new to any type of overclocking so any help with that is appreaciated. At the moment, I can get 13,946 with 5900 XT in 3DMark01. Not sure if that's any good or not.
Also, I have an Asus temp. reader on the system telling me the temp. of the mobo and the cpu. It doesn't however tell me the 5900 XT temp. Is there anywhere I can find this so when I try to o/c it, I can check the temp. on it.
Any help with any part of my system would help. Especially the Gfx card.
Thanks
-AMD Athlon 2800+
-Asus A7N8X-E Delux
-768 MB DDR RAM
-Nvidia 128 MB FX 5900 XT
