M
mfm
Guest
I have searched the various forums and stickies, and I have not found any specific guideline to my question. When adding cooling fans to a case, how should the fans oriented?
I've encountered opinions ranging from:
Any suggestions or a link that might provide some advice? Thanks.
- use intake fans only (and exhaust air through vents, typically in the rear of the case)
- use exhaust fans only (and intake air through vents, typically in the front and side of the case)
- use a combination of intake and exhaust fans
