I put together a Home Theater PC last summer, however now I'm looking into getting the best performance out of it, both hardware and software wise, without spending much more money.
Basic specs:
Sempron 2200+ (1.5Ghz)
768mb of PC2100 ram
160GB Seagate HDD
PVR-150MCE
ATI 9200SE Videocard
Display:
32" SDTV via S-Video Out
What I'm looking for is general guidance on how I could best improve my setup. I am running SageTV which I just invested in the newest version, so I would like to make everything run its best to get my moneys worth. I also just purchased the new PureVideo decoder to use on the system.
As of now, I have SageTV set on the defaults for A/V settings. Using the SageTV Audio and Video MPEG2 decoders. Nothing else is configured, I have AC3 filter and XVid installed, but to my knowledge there not being used. My questions are as follows:
Thanks for helping to point me in the right direction!
Basic specs:
768mb of PC2100 ram
160GB Seagate HDD
PVR-150MCE
Display:
- How would you rate my current videocard as far as tv-out quality is concerned, with respect to the display I'm using. This is the only piece of hardware I'm willing to upgrade, if I can get improved IQ without spending a ton of money.
- Is using DScaler necessary? To my understanding it de-interlaces video, and since my SDTV is an interlaced display, would I be correct in saying DScaler would be useless?
- Is there any sense in using FFDShow at all considering the processor I'm running, as well as the fact I'm only outputting to a 32" SDTV?
- Will the PureVideo decoder I purchased work fine with my current setup? I can't seem to locate any config interfaces for it, I just installed it and it's sitting invisible on my system.
- As far as audio is concerned, is AC3 filter what I want to have enabled in SageTV, and that's it? I'm just doing stereo output to the television's speakers.
- What would you suggest I use software-wise in general, given my hardware and display? Decoders/software/etc. in order to get the most out of my hardware.
