Geminid Meteor Shower Tonight
Terry Olaes
I Used to be the [H] News Guy
Stargazer alert! Tonight is supposed to be the peak of the Geminid meteor shower. Alas, the nearly full moon will likely wash out most of the shooting stars. If you still plan on checking it out, best time will be between midnight and dawn. Good luck!
From around 2 AM until dawn (when our local sky window is aimed directly into the stream) it is possible to see about one "shooting star" every 30 seconds. …Although the rising Moon will greatly interfere, please get away from light sources when possible - it will triple the amount of meteors you see.
Nice! I live in the middle of BFE with nothing but farm land around me... Going to be a nice night to watch this. Though its cold as hell! Gotta love Michigan
Cloudy here as well. Oh well a few weeks ago I made up for it. Saw one of those buggers that lights up the ground like a streetlight and leaves a red glowing trail still faintly visible minutes afterward. Not nearly as spectacular as the one I saw video of over canada, but the brightest I've ever personally witnessed at night. Makes you wonder when a chunk as big as a football field might show up and flatten of few dozen square miles on some random part of the map.
If a meteor the size of a football field hit, it would do a lot more than a dozen square miles of damage. The Arizona Meteor Crater was caused by an impact with an object that was approx. 50 meters across. If you double the size of the object, I think it is exponential growth in terms of the size of the crater formed.
Is there a newsletter or something that I can sign up for that will notify me of celestial events?
Nah, the Chicxulub crater (Yucatan) was on the order of the diameter ratio (Crater/Asteriod) as the Arizona crater, now obviously more material was ejected since we're talking volume not a linear diameter, but overall width doesn't change.
The big things that matter are
1) Speed, since kinetic energy goes as speed squared (mass is a linear term) so an object half as big traveling twice as fast is going to impart more energy to eject material from the crater
and
2) Composition of the object, since something made out of iron is going to dig into the dirt a lot more easier than a rocky object which might have more destruction of the object, or something like an ice meteor which, depending upon size, might simply explode over an area.
Yeah I caught that after I posted and like someone else said it does depend on exactly what hits, but either way the destruction would probably be more like a couple hundred square miles. Either way I'm kind of surprised objects big enough to cause noticeable damage don't hit more often. Considering something about the size of a car would still cause significant damage wherever it hit and there are probably millions of such objects relatively close by.
Would have been cool to see. Got to see about 4 inches of snow drop in a few hours instead.
The skies were clear over central Alberta. I watched for about 15 minutes starting at midnight. Looking north I saw a bright orange meteor shoot over a good stretch of sky. One of the brightest I've seen in my life. Thanks for the heads up Terry.
Driving home from a party at AT&T Park in San Francisco last night, I saw an extremely bright meteor. I guess this is why...
