geforece ti400 =game corruption
fallnangl
ok i have posted before but i think it was in the wrong forum..its definatly the video card. but the problem is that whenever i try to play Prince OF persia the sands of time the people are stretched out like taffy(there haeds are strecthed and leaning over ,the body arts are all slumped over).. i have screenshots but i have no webspace to show them. the background looks good sounds fine its just the characters. I AM BEGGING for someone to please help me i bought this game and for the last month has been unplayable. have done everything in the in game settings to fix this. thanx to any that can help.
What drivers are you using? If your using anything other than the the 45.23's uninstall them and try those. Those are the best ones for the Ti's, IMO..almost trouble free. If that doesnt work turn down all the affects/settings to the lowest and see if it goes away...if it does you know its some setting not favoring your card.
installed the older drivers and the 45.23 gave me the least amount of problems. im using 5303 drivers now, have also tried turning the settings down as well.anything else that could be the problem??
