GeFORCE4 Ti4400 vs GeFORCE 6200
Megengo
I'm looking for a cheap upgrade for my girlfriend's computer, mainly so she can play BF2 with me. She currently has a GeFORCE4 Ti4400, and I was thinking of upgrading it to a new 6200. What do you think? Would this even be an upgrade in performance over her last card?
Make sure to get a 6200 non-TC, these can be unlocked from 4 pipelines to 8 pipelines w/ Rivatuner which gets you a 6600 for cheap.
True to an extent. It's not guaranteed that they will operate within nVidia spec when unlocked.
Thanks for the help. I have been looking for a side-by-side comparison like that for a while now. And I think I will just get the 6600. It's only like a $100 card.
There is a difference in preformance in those two cards. For one if you plan to play BF2 at all the GF6200 will at least play the game.
KM
Yeah nothing below an FX will even play the game. And a 6200 can be unlocked to 6600 and the o/ced close to GT speeds (of course no DDR3). So a 6200 is deffintely the way to go.
you mean load...playing is a matter of opinion with this game lol
The cheap department is the only one where I would bother getting an ATI. The Ti models don't have the ability to play games like BF2 and some others that are going to come out like UT2007. The 6200 really does lag in some games according to benchmarks I've seen. So, you have a choice of 9600 Pro, X700 Pro or those who want to aim a little higher and can spend a little more, the 9800 Pro (which I've seen way cheaper than the 6600 GT).
a 6200 will be faster in newer titles b/c of its more advanced/powerful pixel shader capabilities...
However, in older games and 3dMark 2001, the ti4400 will be faster.
Ex:
My brother's Pentium 2.4B with ti4200 scores about 10,628 in 3dMark2001
My work PC. w/ P4 3.06Ghz and 6200 scores about 8,200 in 3dMark2001
And in some new games, b/c the ti4400 will default to a lower quality level (ex: DX8 vs DX9), it will be faster than the 6200 running in DX9 mode. And the actual visual quality will not be that much different if the game is coded properly.
Personally, I would hold off, b/c its not really an upgrade, as much as a horizontal movement where you're add a few features. Wait a little longer, and get a 6600, 6800nu, etc... Hopefully, in the next few months as the next gen 7000 series hit the market the older 6000 series should drop in price even more. But I think the 6800nu is the best bang for buck around right now.
i thought the turbo cache were only pci-e cards
if you can get it to unlock the 6200 will be much better than the 4400
Good choice. Go for the 6600.
