Geforce -> Quadro
DontBeEvil
Few quick questions.
Is the hardware any different?
I think I've read a Nvidia white paper some time ago where it points to an architectural difference, a minor one though. So, I'd assume they simple disable that for Geforce cards?
For some performance tests, see this thread.
Some of the older Geforce cards could be softmodded into Quadros, but Nvidia has engineered that possibility out of newer cards.
The difference between the two is much more about driver support than differences in hardware. Businesses making money designing buildings are much less tolerant of bugs in the drivers than gamers are.
Same core but different parts used for different lines (GeForce, Quadro & Tesla) at least as explained to me by this guy.
Are you sure it's the exact same GPU and there's nothing disabled (hardware wise) on desktop GPUs?
The only hardware difference is that Quadro's have more VRAM, but its slower VRAM. Nothing in the GPU is different. But it doesn't matter because the drivers are different. Without the drivers, the hardware is useless. So if you have an app that wants a Quadro, a GeForce isn't going to work as well because the driver's aren't there for it.
As far as I know they are no longer software modifiable. I think they put something like a hardware quadro ID on board. So the architecture is the same, but there is some on board modification that prevents us from revealing the spade. I'm not sure if that is accurate, but I know it is now a hardware solution.
Alright thanks guys.
I knew it is or was possible to hack the drivers and get pretty much the same performance but I was just curious whether there's any difference in the architecture itself.
Well, the quality of the hardware is probably different. Quadro cards are tested much more rigorously. People who spend $2,000 on a graphics card for work expect it not to fail on them.
