It's been said that this video card has two Dual Link outputs, plus an HDMI output. Does anyone here know if that HDMI output will be linked to one of the Dual Link, or if it is separate, allowing for 3 monitors non-mirrored.
NKDietrich, I'm confused of your response. If what you're saying is true, then why wouldn't they have just put One DVI and One HDMI. Why keep two DVI on there, and add an HDMI? It seems they have added the HDMI for a reason, otherwise they would have just included a DVI to HDMI cable.
HDMI allows for both Video and Audio, since it's a 5 GHz. Whether it's carrying both in this particular instance, I do not know.
Any more information would be greatly appreciated.
Sorry to burst the bubble, but unless you disable the SLI on this card chances are your only going to run one monitor. To make matters worse I wouldn't be surprised if it was just the audio pass through / marketing reasons why they put the HDMI output on the card. It will simply replace the classic "S-Video" we got so use to seeing on other cards. Of course all of this is just my opinion, because I like everyone else who isn't under a NDA has no first hand knowledge of the card.
I have a 7950 GX2 that I'm not running in Multi Monitor Mode. Are you saying that only one chip of the two is actually working?
ATI was able to support multi-monitor CrossfireX. I'd be surprised if NVIDIA isn't doing everything they can to match that. Hey, wasn't the GX2 delayed for driver reasons (a clue, maybe?)
