Geforce 7025 comparisons?
sparky3009
Got a mobo with the nforce 630a/geforce7025 chipset.
Can't find any info on the 7025 video card online, or how it compares to any card. Anyone got any idea what nvidia or ati cards it compares to?
Probably comparable to a Geforce 6200 or Radeon 9600 in terms of performance; maybe a bit worse.
I figured it was pretty horrible.... The reason I'm asking is because it is HORRIBLY slow... can't even play WoW.
I would put the 7900gt in but I don't have a dvi adapter and I'm using some POS CRT that has lines like vibrating down the screen. YAY FOR HEADACHES!
I initially set my HTPC up with a GeForce 7050-based motherboard. It was capable of playing Guild Wars at 1280x720 averaging about 20 FPS (no FSAA). So at lower resolutions, you should be able to play WoW (at least, if you don't have WotLC), but expect your frame rates to tank occasionally.
I've now stuck an HD4550 in my HTPC - GW maintains 60 FPS at 1280x720 with 4xFSAA and maximum quality settings ...
The simple fact is that you've got integrated graphics from 3 years ago. You can't expect miracles. If you want to play WoW, buy an HD3450 for $20 or so - or splurge on an HD4350. Or pay $5 for a DVI -> VGA adaptor.
