geforce 6800 to Quadro mod
CAD OC'er
I haven't accomplished it, but does anyone know of how I can go about doing that? or is it possible?
The newest quadro series supports sm3 and sports ddr3, so I would assume its based on the 6800 core.
There hasn't been a soft-mod for a while. There are resistors on the GPU package that are epoxied over, so good luck.
edit: some people got the SoftQuadro4 tweak to work on their FX 5900 cards with maxtreme drivers, but I haven't seen any 6800 soft mods yet.
and PCIe, and SLI and up to 512MB of ram!!!, etc... .
any links for that maxtreme drivers? TIA
joemama said:
Does Nvidia even have Quadro's based on the 6800? :confused:
Hi
anyone knows about mobile environment?
Chances to mod a 6800 Go Ultra in a Quadro?
I'm buying a laptop with that card, i'm interested in OpenGl perf and i'm in time to change the order and put a FX1400.....
Pls help, tks :D
i've seen some people that got quadro labeled cores on their 6800's. i believe the cores are the same there is just some physical difference with the circuitry on the rest of the board (probably a small one)
