GeForce 6600GT w/ Doom3 $217
Matt Woller
NewEgg has a Leadtek GeForce 6600GT with a copy of Doom 3 in it's bundle for only $216.99 shipped!
Linkage
*EDIT* Also includes Splinter Cell: Pandora Tomorrow as well as Prince of Persia: The Sands of Time, bringing the value of the games bundled with this card to approximately $130.
Oops, forgot to mention... it also comes with copies of Splinter Cell: Pandora Tomorrow, as well as Prince of Persia: The Sands of Time!
Yeah, if only it were 3 or 4 weeks from now... then maybe somebody would actually be able to use the card. And a good $130 in free games, too. :(
Damn..that is SUCH a nice deal!!
If only it was in December when i upgrade..
Not bad! I guess you have to consider however how cheap 9800' pros have gotten recently. Got mine months ago on sale for like $150
Yeah, you can pick up 9800 Pros for about $195 from NewEgg (PowerColor sells a version called the "EZ" which is a 9800 Pro with slightly underclocked RAM... by 75Mhz), however if you consider that the 6600GT is about on par with a 6800 Vanilla... and a 6800 Vanilla out-performs a 9800XT significantly, this isn't bad. Also, this card is priced somewhat competitively against other 6600GTs, which makes the bundle all the more appealing with it's $130 in free games (of which Doom 3 is included).
anyone else notice that they didnt take out the serial number on the doom 3 cd case in the photos?
I noticed that. Too bad no one on this board needs a serial right. We all own this game right.....
hahaha thats great! some poor guy is gonna buy this package and not be able to play doom3 online though :rolleyes:
is the Audigy ZS gamer from Newegg 109 but it comes with
Halo
Jedi Knight-Jedi Academy
Splinter Cell - with 3 addtional missions
Tomb Raider - The Angel of Darkness
Rainbow Six 3:Raven Sheild
I picked it up from NE when they had a 30 dollar rebate too -
But what's up with e 128mbit mem bus? 256mbit is where it's at! The Saphire 9800pro or other Saphire variations have a 128mbit bus which is why the card is cheap as well as sux.
I'm no nVidia encyclopedia but you guys may want to make sure that the 6600gt's you saw test are 128mbit and not 256mbit or you'll feel a little booty in the end.
Heh, the image has since been tweaked
It makes alot of sense to come out with the pci express in a budget card when pcix mobos are rare and quite expensive. :rolleyes: You think agp cards would be the first out the door.
A good deal none the less for anyone that could use it.
If you'll kindly look up some benchmarks for the 6600GT, you'll see it outperforms a Radeon 9800XT (which has a 256-bit bus) quite significantly. It's not all about the bus, nor is it all about the pipelines (the 6600GT only has 8, like the 5900 and 9800 series cards). That is a common misconception, and indeed cards of the past that only had a 128-bit bus were disabled, but the 6600 (and x700 while we're at it) series knows how to use it's bus, persay, and is therefore un-affected by it.
Well, all that matters in the end is performance. The 6600GT has only a 128-bit version... that's it... there is no 256-bit version. The fact is the card beats a 256-bit 9800pro no problem. It would slaughter a 128-bit stripped down 9800pro. Probably helps it has DDR3 clocked at what 500MHz or something :p ... anyways yeah the one you saw in reviews is 128 bit.
Buy perfromance not bits. The thing with the 9800pro was we all knew exactly what they perform like... but you could accidentally get less than you expected (128 bit) with slower performance. No stains on this deal.
EDIT: Ok I didnt read everything so I guess I got beaten to the punch. However, it has nothing to do with the fact it "knows how to use it's bus." Going to 256 bit doubles your Bandwidth at the same MHz. This thing simply has enough MHz that it does not have much of a bottleneck by having only a 128 bit bus. Being that this card starts it's life way under $400, it's not economical to implement 256-bit on it. It raises PCB costs etc. 500MHz is probably enough to fill the needs of the an 8 pipe core.
The ram MHz makes up for the lack of 256-bit. If it's memory ran at 310MHz or whatever like the 9800 lite version does it would drop to it's knees just the same. Bottlenecked badly. Using the same high speed ram used on much more expensive models saves the card. Spend more time on designing a tricked out pcb or spend a bit more on Ram was nV's choice and they went with GDDR3.
Actually, I fully meant "using it's memory bus effectively". Take, for example, the Matrox Parhelia. This is a card with (depending on what version) had a 220Mhz core, 500Mhz RAM, and a 256-bit memory bus. However, the card was thoroughly beaten by a GeForce4 Ti4200, which is a card featuring 225-250Mhz core speed (again, depending on who you bought it from) and 500Mhz RAM speed with only a 128-bit memory bus.
My point is, it's not about the clock speed, RAM speed, bus width, or pipeline count, but rather the GPU's architecture. That's what I was trying to get at. ;)
Well, for one thing you use DDR speak which can get confusing. The parhelia does not have 500MHz ram. Probably has ~250MHz or whatever it is for ram and a 256 bit interface. Even still it's problem is it's core is way to weak. Anyways. lets not compare a POS architecture to these cards anyways. Point is the 6600GT has real 500MHz read 1GHz DDR speak. An 8 pipe core does not need more than the 16GB/s that DDR3 provides at 500MHz and 128-bit. A cost saving measure nothing more.
All I'm saying is "it uses it better" is pulled out of the air. When speaking of why the 9800 lite gets hurt, it is much more based in fact that the problem is it's ram is clocked much lower. Is it not more accurate to say the deal here is the 6600GT rivals the bandwidth of that 8 pipe card, so it's not a big deal? I certainly think so. You can find cases where the 9800pro's bandwidth advantage actually plays a role, but such is life. The 6600 core is much stronger.
Raw MHZ does seem to produce more useable bandwidth. So in this sense it uses it better. So this helps, perfomance wise, close the bandwidth gap but this is true of all 128 bit cards. ie. 500MHz 128 bit > 250 MHz 256 bit. This can help it perform well in even memory intensive scenarios against the 9800pro. However, this doesn't mean much when comparing it to a 9800 lite.
You say it's not the MHz... which totally refutes my whole point, and not very well at that. Clock the mem down and it will choke. 16GB/s is enough for an 8 pipe design... and that's that. A direct comparison was made to the 9800 lite which has a bandwidth in the neighborhood of 9GB/s. Numbers.
In general when you speak to someone technical about video cards "using memory bandwidth better," it has more to do with stuff like memory-compression algorithms. You seem to be using performance as a sole reason to go ahead and say "it uses it better." I just tend to get a bit technical I guess. I want to inform why it's really not effected as much in this DIRECT comparison. Just seems like the info is being shit on to rationalize a statement I am not trying to chastise you over. :(
Ok re-reading... I hope I didn't come out harsh. You seem to want to cover your statement for fear of looking wrong in some way. So certainly you can understand I would too.
My statements even can be bent into saying it uses it's bandwidth better. Maybe it can use it's 16GB/s well but it still has a formidable figure for a mid-range card. Just at the end of the day.... bit width does not matter that much to us so long as the memory bandwidth (still important) is there to throw up our pretty frames right? The 6600GT is no slouch with its slim width only because the MHz are there. You wouldn't want it having 9800 lite type figures.
All I was trying to get accross is that you shouldn't make a purchase decision based on a number, but instead on performance. The user I was making the comment to didn't understand the fact that a 6600GT with a 128-bit bus was significantly faster than a 9800 Pro with a 256-bit bus. You can say all you want, I was merely attempting to explain the rather large difference to somebody who obviously didn't know said difference.
On a side-note, this package is still $217 after shipping. Doesn't look like it's going anywhere. ;)
midgetherder said:
$217 is not that [H]ot
http://www.newegg.com/app/ViewProductDesc.asp?description=14-125-156&depa=0
$184 + $1 Fed Ex Saver.
Doom 3, component out box
Or is there something great about the Leadtek I don't know?
That's because it is the PCI-E version which has been out for a couple months already. The AGP version just came out and will be similarly priced in a month or so I bet, especially when all the other brand 6600GT AGP cards come out. I will be buying the an AGP 6800GT when the price is in the 170-180s.
I think it was the fact that a) the deal you mentioned wasn't listed on NewEgg at the time of this discovery, and b) the deal listed at the start of this thread has around $70 more in free stuff, thus slightly elevating the "deal value" if you're one who wanted one of the games that came with this bundle. With that being said, for the gamer who just wants a 6600 and doesn't really need anything else, not only is the deal you suggested very nice, but the Doom 3 inclusion is incredible. I'd email Steve or Kyle that deal... it'd probably make the front page.
