GeForce 6200 headache
Systems was as follows:
Asus A7V400-MX
Athlon xp2600+ boxed 333Mhz
1024 (2x512) meg ddr 400
WESTERN DIGITAL 80 gig 7200 8 meg cache
My problem is that I installed the following Graphic Card:
XPERTVISION GeForce 6200 256mb dvi, tv-out 128 bit
Now I have nothing but problems. Cant resize, redraw, fuzz all over screen etc etc. especially with Windows XP (Service Pack2).
Ive tried latest drivers from NVIDIA. No change.
Can anyone help?
Thanks!
Does it work normally when you're not using the nVidia drivers (IE - during boot, installation of windows or going into VGA mode)?
Get updated motherboard (especially AGP) drivers, and latest drivers for the card. Also, have you removed all (absolutely all) of the previous graphics card drivers? If they are still there they can cause some issues.
I do know of some issues with drivers and Service Pack 2, just make sure your system is in tip top shape, make sure you have the NTFS file system, not FAT32, and make sure there are no virii etc. These can all make a difference.
What kind of videocard did you have before? Did you completely uninstall the drivers for it?
