GeForce 6150 & Server 03
batteriesnotincluded
My workplace is setting up a new AV server for testing purposes (may go full time if we commit to this AV product). It's been reformatted from XP Pro to Server 2003, and uses an AMD/nForce 6150 combo instead of our standard intel/intel setups.
I can't for the life of me find a viable driver for Server 2003 32 bit. Anyone have any suggestions?
*update* Nothing like incomplete information; it helps when you're finally told that the system is running off an add-in card, not the onboard these systems usually run off of. Also makes things a lot easier when you find out it's a Radeon x1300, not a GeForce 6150.
