Geforce 460 Sli Enabled causing sound popping
Singuy
I am wondering if there's a fix to this issue. I am getting a bad stutter/popping sound issue with the nvidia sli enabled. This popping issue happens with the use of the onboard sound card and a pci sound card.
Windows 7 64 bit
6gig of ram
gigabyte x58-udr3
2x gigabyte 460 1gb
1000watt psu
have you tried disabling the audio device thats built into the GTX 460s? I can find some detailed instructions for you if you haven't..
probably an obvious step you've already taken but i'll suggest it anyway - have you updated all your motherboard, sound card, and video card drivers?
Yes, I have tried disabling HDMI out, using HDMI as sound, installed all drives and did all the updates. This may be very specific to my motherboard because I am not the only one having this problem.
