SystemERRor said:Im not sure if your card can do it, but check the nvidia driver settings (and check to see if you have new drivers). On mine i have "Digital flat panel settings", which lets me change the way my monitor displays things ( stretch, strech (but maintain aspect ratio), center, etc).
On that note, what setting are people using for this? I am using "Monitor Scaling". Should i be using "Display Adapter Scaling" or "Fixed Aspect Ratio Scaling"?
The monitor can do scaling but not sure on Nvida cards. On my ATI card>>>Digital Panel Properties>>>Attributes>>>Image Scaling, I choose "Use centered timings". Once done you have to choose a resolution (desktop or gaming) that is in the 4:3 ratio. You will get black boaders around your gaming or desktop screen.
Hope this helps.
