Gateway XHD3000 Need some help please~!
Zepharus
I just recently purchased this monitor about 3 days ago. I have just recently noticed that when viewing a full screen GRAY only backround ( no other colors produce this) the display has a very face pace random flicker effect in the upper right area of the screen. It is in an odd shaped area on the right side..very difficult to explain. It simply only is noticable on gray.
I search high and low and can find NOTHING on this issue. Is this a defective panel? Do I have color setting vastly wrong? I have tried recalibrating color with the eztune that ships with it to no avail. Any thought here would help
Does it look like circular? There was an issue with the xhd3000 called pulsing screw where the pressure of ascrew on the screen could be seen in some colors.
No definately not the screw issue. It quite honestly looks like the backlight is flickering only in that oddly shaped area and only visible on a a gray backround.. Im starting to get irritated
I agree but I have a request PLEASE, can anyone that owns this monitor, go to this page
http://www.wowwiki.com/World_of_Warcraft:_Wrath_of_the_Lich_King#Dungeons_and_end-game_content
Please tell me if you see any flicker to the right of the text in the open grey area? If I can get multiple peple owning this Disply to post here it would be appreciated. Thanks in advance!
Negative on the flickering here as well.
I must say, this piece is a BEAST though, hopefully your next unit will treat you more nicely
thank for all that helped.. I guess Ill go online to Newegg now and request an RMA....
