Gateway XHD3000 -- Heat Output???
I'm considering the purchase of the Gateway XHD3000 30 inch monitor. I've read many of the online review including the excellent discussion on HardForum.
There has been scattered reports of high heat output, yet it has not been universal. Some reviewers have reported the monitor as being a "space heater" that will make you "sweat." In fact, Vega posted the following about a month ago in this forum, but no one else latched onto it and supported the conclusion. Vega wrote:
"Another issue worth noting is the heat the unit puts out. You can't really feel it when you sit a couple of feet away but you definitely can if you get within a foot. That will help you in the winter but hinder you in the summer for us Northern Hemisphere dwellers. With pretty much everything over clocked in my desktop, multiple computers and this LCD, my air-conditioning power draw will definitely be higher this summer!"
For those of you who own this monitor, I would like to get your feedback. I would like to know how big of an issue this is and under what conditions it might impair your enjoyment of the monitor.
In my case, I compute in a large room with my head about 30 inches from the monitor.
I look forward to this group's thoughts.
I sit about a foot away from mine and I don't notice any heat. I do notice it if I put my hand behind it though. Its a big display that needs lots of power to run. My electric bill has gone up since I have gotten it.
Also be aware of the high input lag if you intend to game with the XHD3000. Also, the native resolution may be a bit overkill for some and requires a serious rig to game at the native resolution. Other than that its an awesome display with superior picture quality and amazing features.
