Gateway VX720
TheOne&OnlyZeke
100% Irish
Does anyone know how to fully reset this type of monitor?
mine has a kind of blueish hue to it...and i've messed with every setting on it to try and correct the colour but nothing is working.
yet i can't reset it
i found a geometry option but that doesn't do anything as it comes up with the error
' user timing, cannot b reset'
anyone any idea's?
anyone any idea's?
Sounds like it needs gray scale adjustments which as a rule, unless you have the right tools I don't suggest.
What's easy to do on an LCD is much harder on a CRT..
