Somehow my friend fried his Gateway. I tried everything and couldn't get it to post. I narrowed it down thinking the MB is fried. Problem is I'm trying to persuad him from buying a MB from Gateway as his warrenty is no longer any good. When I was looking at his case....I noticed Gateway has a different style of MB then I'm used to. Looks like the audio plug ins on the board go horizontal as opposed to Vertical (which Im used to from AMD boards, not sure if its the same with Intel boards).
This is the current MB http://support.gateway.com/s/MOTHERBD/INTEL/2516231/2516231sp143.shtml
And the techinical referance showing the setup of all the line in and our audio stuff as well as serial ports...USB etc etc http://support.gateway.com/s/Manuals/Desktops/8508559/08559.htm
this shows the configuration of USB/Audio inputs video..etc. My question...is there a cheap board out there that uses this same configuration so he can use his current case? Thanks
