Gateway Laptop Issue
midnightsaga
I have a client that set a power on password on her Gateway laptop and then forgot it. Is there anyway I can remove it, so I can boot?
Clear the CMOS. Remove battery for 5mins, that resets password.
On most desktop boards there is a jumber you can pull to change the bios password.... i would call gateway and see if they dont have a master password.... otherwise looks like you will have to open it up.....
try
password and admin for passwords
what model, my uncle works for them
