When I play DVD over component 2 with the XBOX 360, I noticed that the image is not stable and flickers, like the monitor loses sync very frequently. It does not do that when I connect over component 1. Has anybody noticed such a strange behavior or is it just my monitor?
ok I just ran the Prad.de test on my Jan 07 MGQ71 monitor I've been complaining about ghosting on.
The inverted ghosting, and the amount of it is just stupid.
I'm 99% sure I'll be returning this monitor, but I'm on the fence about what to do here.
Do I try to exchange it for another MGQ71 and hope that one doesn't have these issue?
Do I try to exchange it for an earlier model? Say a DEC or NOV pannel?
Or do I just say fk it and get a 22" instead?
I'm a heavy gamer, video editor, I do some 3d modeling, and frankly this ghosting is just unacceptable.
Any advice welcome.
If it bothers you that much I really doubt another model is going to be any better. I game and browse and find the monitor exceptional, however some people are more sensitive to issues like ghosting etc so my advice to you, after owning 4 Gateways myself, is to get another monitor. I really don't think going through another return is going to yield you any better results if it is really a stand out issue.
We also tested Battlefield 2142 with the FPD2485W. Even though EA does not support widescreen monitors, we used the + widescreen 1920 x 1200 switch on the shortcut and got acceptable results. There was no noticeable ghosting or motion blurring, and the level of detail was exceptional. All in all, the FPD2485W does an excellent job of showing off everything this LCD panel can do. Keep in mind that most manufacturers use the same actual panels with their own circuit boards and casing, and the important thing to note is that Gateway is able to run with the best of them when it comes to the FPD2485W.
Ferris, for some time now I've been suspecting that you work for Gateway. Would
you please refute this idea by literally showing us how great your FPD2485W is? How
about posting a video of the ghosting test http://www.prad.de/en/monitore/ghosting2.html
and some FPS gaming--if you can--so that those of us who want to exchange this
monitor can have some hope?
By the way, the number of times you're complimenting this monitor every time someone
say something bad about it is getting really annoying, and I think everyone who keeps
having problems with the monitor (I have three times) would agree. If you're trying to
encourage us to not give up on this monitor, I understand--but please, every time you
boast about your monitor is a stab in the heart. So please, be considerate.
The quickest way to cancel a great deal at Best Buy is by buying accessories like cables from them. Their "Geek Squad" brand products are priced absolutely outrageously. For comparison, Monoprice.com sells very high quality cables, and a 12 foot DVI cable will run you a whopping $6.03 plus shipping. Contrary to what a salesman might tell you, there will be absolutely no improvement in quality with Best Buy's cable. If it's possible to return it, I would.I needed a longer DVI cable, picked up a 10' for $50 bucks, and they even applied the 10% discount to it.
Nice dealin', swetmore. I love that. I'm hoping to swing a better deal soon, and that's a nice trick. Thanks!
No problem, swetmore. Let us know how you like the Gateway once you've gotten a chance to play with it.Thanks for the tip on the DVI cable. Just ordered one on-line. Came to $10.08 shipped priority. I will take that cable back to Best Buy. I actually knew I was paying too much for the cable, it is just that I was pressed for time. So I will get another $39 by taking that overpriced cable to Best Buy. Thanks Again!
Here are some pics of the ghosting. Like I said before its not the fact that it ghosts that bothers me, its the dark colors that it ghosts...
WOW! That really is insane.
Surely there must be some pattern here as it seems even some folks here with higher end systems still show poor results. Using the test above my Nov model shows only the slightest faint shadow. Are you using: EzTune? VGA / DVI?
best
JMD
Got some pretty annoying video ghosting.
Monitor is connected to my pc with this Belkin Dual Link DVI cable
http://www.newegg.com/Product/Product.asp?Item=N82E16812123021
Also tried the supplied DVI and VGA cables that came with the monitor.
Still has the problem.
Computer pushing it is:
Thermaltake Armor Series VA8000BWS Black Aluminum / Steel ATX Full Tower Computer Case
EVGA 122-CK-NF68-AR LGA 775 NVIDIA nForce 680i SLI ATX
Intel Core 2 Duo E6600 Conroe 2.4GHz 4M shared L2 Cache LGA 775 Processor
ZALMAN 9700 LED 110mm 2 Ball CPU Cooler
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 800 (PC2 6400)
Creative Sound Blaster X-Fi XtremeGamer Fatal1ty Professional Series
Western Digital Raptor 150GB 10,000 RPM 16MB Cache Serial ATA150
SAMSUNG Black 18X IDE DVD Burner With LightScribe Technology
eVGA GeForce 8800GTX 768MB 384-bit GDDR3
OCZ GameXStream 700W Power Supply 100
To quote myself from a previous post :
I have tried with eztune, tried without. Tried the color definition file provided earlier in this thread, made the colors nicer, but didn't change the smearing/ghosting issue.
Addition information:
Manufacter Date as recorded in eztune AssetID: Week 03, 2007
EDID Revision 1.3
MGQ71
Painboy?
I will post some more photos and a video today at some point. I am watching my daughter today (4 months) so I have to wait until she falls asleep.
All of the video hosting services I know compress the videos. If you want them
uncompressed, you need to use a file host which only let users download the video
instead of play them in the browser.
http://www.eggdisk.com/
http://ihud.com/new/
Ghosting Test:
http://www.prad.de/download/pixperan_english.zip
Inverse-colored trailing is normal for monitors with overdrive and is usually most visible against dark gray. I've seen it on every monitor with overdrive, although I find it's worse on monitors with S-PVA panels since they have bad gray-to-gray response times to begin with.There are two red squares in the picture. This is normally how ghosting looks when taken with the same speed setting on my camera on my other monitor. But on the gateway (the pic) you can see an additional lagging inverted square. I look at different manufacturers LCDs all day at work and have never seen another LCD display do this. This is why I think something else maybe going on other just normal LCD ghosting. If the inverted field wasn't there I wouldn't care honestly.
I've seen this problem on the Eizo CE240W, and I hear the Dell 2407WFP has the same problem. It's caused by the crappy overdrive implementation used in some monitors with S-PVA panels. Changing the brightness or color settings might eliminate the effect.I noticed bad trailing when viewing default phpbb forums, it leaves a pinkish trail that looks just awful.
http://www.phpbb.com/phpBB/viewtopic.php?t=500954
I also think that most of the 'so called' problems with the monitor, is mostly over pickey people. The posted example of bad ghosting is not the norm for this monitor. All LCD's ghost. LCD's that normally have a small trail on 12" screens have a more noticleable trails when you blow them up to large 24" wide screens.
Out of all of the reputable reviews posted by profeshionals on the net, they all seem to echo that this is a high end and respected LCD. It is at least as good as the other 24" wide screens out there currently. I think it's the best 24" wide HD currently out, baring the Apple 23" $994.00 or $2199 for the 30" screen. Apple has quality displays, but come at a a ripp-off price. The FDP2485W is the best bang for the buck going in the 24" HD wide screen arena. I keep hoping the few users who dont like their monitor will just take it back and move on.
Hopefully the vast majority of us who like our FDP2485W's, wont have to spend so much time plowing through so many posts of the same people bitching on the same issue.
I am afraid that sombody actually knowing about LCD's and how they act, might get the wrong impression of this display from this thread. This is a great monitor, with a decent price. Is the the best display that will ever be made in the history of man? Probably not. But for 2007 is pritty darn good.
If you dont like your LCD, return it. Life is too short.....
I would rather read posts about using your LCD to the best of it's abilities such as calabration or color settings info.
