gateway fpd2275w question ?
Devilspunkboy
ok i just got this monitor im trying to hook my ps2 up to it and its not working i tryed hooking it up with component cables and composite no picture nothing comes up any ideads or anybody elise have this monitor
I assume you switched from DVI or VGA (whichever you are using for pc) to the component input through the OSD?
Try different cables or maybe something else like a dvd player through the component inputs just to eliminate the PS2 itself from being the problem. If you can't get anything to work through component then you'll want to take it back to the store for an exchange.
