Gateway FHD2400 Input Lag
X-ray Doc
This monitor may be in the process of being discontinued, since Gateway has released the FHD2401 with fewer (not newer) features. But I managed to buy one at Best Buy last week and just finished doing some input lag measurements against my ViewSonic PT813 CRT. The results are quite good so I thought I would post them.
I took a ton of digital camera images of the stopwatch cloned on the two monitors. My lowest time difference was 0 ms. My highest time difference was 16 ms. The average of all the images was 9.13 ms. I wanted to buy an LCD that would be good for FPS gaming. I think I found it!
P.S. Wikipedia has a page that claims we should be calling this "output lag" instead of input lag. What do you think?
http://en.wikipedia.org/wiki/Input_lag
Thanks for the measurement.
I think we should call it "input-lag", becuase "output-lag" can indicate that it is a problem of graphics card :)
