Charlie91c8
- Aug 28, 2006
I have a Gateway NX860XL w/ Vista home Prem. I have a factory CD that came with it. If I wanted to get rid of all their programs and behind the scenes apps will the factory cd do a clean install or will it replace all that junk (Mcafee, etc) right back on? Should I get used to uninstalling things and do they really fully uninstall. I think I need a program cleaner app heh.
Otherwise if I can get some bloat out it's awesome.
