evilmonkey
- Dec 16, 2003
I have the opportunity to get a Gateway Destination XTV-366c computer and its monitor for $125. Unfortunately it does not include the wireless keyboard or remote, but I've seen those on eBay for a price. I would really just be using this for a tv tuner and maybe to record some shows. I don't know what OS or software I would put on it yet, suggestions are appreciated. Also I was hoping to switch out the motherboard and processor to a mid range athlon, since it only comes with a celeron 366mhz (eww). The case seems to be standard ATX so I hope to not run in to a lot of problems there. Do you guys think it would be worth it to take advantage of this? It has 2 sets of A/V outputs and at least one set of inputs, as well as what I believe is the original All-In-Wonder card with the coax and vga on it. The 27" viewable screen is also noticably larger than my 20" Apex right now. Opinions on the quality of the system or why I should or should not get this are appreciated. Thanks.
-EM
-EM
