gart driver only?
arnemetis
Hi I have an a7n8x dlx mobo and got my new 6800gt in, but it says it is running on the pci x0 bus instead of agp8x, ive read alot that installing the latest agp drivers will often fix this, but i cant. ive downloaded the file repeatedly from different locations, but when i start the setup, it will show the splash, then show the progress bar saying it is preapring the windows isntaller, then close. nothing. no lingering process in task manager, no error message, just gives up. i dont have the time to deal with a windows reinstall, is there a way to manually update the agp drtiver without using that satupid all-in-one? i figured it must be possible to update it somehow, with its own folder and inf file. any suggestions OTHER than reinstall windows would be much appreicated :)
same thing happened to me with a nf7-s and a 5600 ultra just install newest mobo drivers and it should be fine
thats the thing...the mobo drivers WILL NOT install! regardless of what i do, ending every task known to man, or even safe mode, it starts, shows the nvidia splash, then poof gone, nothing. ive tried downloadign from difference sources, even different, older versions, nothign seems to work. I think I am just going to have to bite the bullet and reinstall windows, the multi day taks that that is :(
careful.....
the agp bus is bus 1 dev 0 function 0
the PCI bus is bus 0 dev 0 function 0
I assume your settings is showing no AGP?
What does it say in sissoft sandra?
the VIA 4-53 Hyperion can be extracted from D/L zip to an .exe for install
however it can further be right click extracted to all its component parts to a folder you name
the agp stuff for XP is in the AGP named folder
you might want to completely do your "refresh" of chipset drivers in safe mode, first uninstalling all. First use device manager "remove driver option" in all PCI-CPU-AGP bridges shown in sys devices while in normal mode. You have to force reinstall.
(The exe isnt working because it sees everything already in.)
then boot into safe mode and install all.again
Windows file protection tends to hold onto these files
oops, everyone posting while I was typing
